No matter how much acid I use, it doesn't go any higher than 6.5. My pool is pebble tech with a SWG and is 12,000 gallons. I live in Arizona and pool temp is at 80 degrees I used 2 different pool testing kits to test the water. Last summer I had a problem with black mold from high nitrates, drained enough water to reduce the nitrate level. I use Leslie pool acid. Thanks for your time
Jim
Jim
