- Sep 20, 2024
- 13
- Vinyl
- Intex Krystal Clear
Just ordered the:
As I’m waiting for the arrival of the pool, I’m figuring out the best area for the pool, how far from the patio, and the best sub flooring. I’ve read about leveling and my OCD should take care of that.
Is 3’ from the patio sufficient?
Should the leveled area and foam extend a foot out, 19’ instead of 18’?
After foam is set, do the legs/cement blocks go on top of the foam or just outside/beside it?
Should I make the blocks flush with the sand or should they sit above the sand?
Also, my yard is decently sloped so I’ll need to gradually remove more soil towards the back. Anything I should consider regarding this?
So far I have staked out an 18’ diameter circle. The electric is on the left side of the patio when facing the yard. It is a bit overwhelming to begin digging out the sod. Any encouragement is appreciated! Thanks in advance…
Intex Ultra XTR Frame 18' x 52" Above Ground Swimming Pool with Sand Filter Pump, Ladder, Cover, & Maintenance Accessory Kit with Vacuum and Skimmer
And the…Intex Krystal Clear Saltwater System for Above-Ground Pools up to 15,000 Gallons
It fit my budget and relieved some of the decision making regarding compatible accessories.As I’m waiting for the arrival of the pool, I’m figuring out the best area for the pool, how far from the patio, and the best sub flooring. I’ve read about leveling and my OCD should take care of that.
