- May 3, 2014
- 62,717
- Fiberglass
- Pentair Intellichlor IC-40
You can purchase CYA (aka stabilizer, conditioner) powder at Home Depot or maybe Walmart. Typically a 5# jug costing under $20. You then calculate, using PoolMath, how much powder is needed to raise your CYA (assuming you are doing a complete drain) by 30 ppm in your volume of water.
Add the CYA by using what we call the sock method. Get an old sock (no holes) and put the measured amount of CYA you need. Tie the sock closed and either suspend it in front of a return (hang it from your brush pole works with something weighted on the deck) OR if it still allows flow thru the skimmer, place the sock in the skimmer. Every 15/20 minutes give the sock a squeeze to speed up the process. Please DO NOT follow the directions on the container of CYA to just pour it into the skimmer and don't just toss the sock in the pool as the CYA is acidic and can bleach/stain pool finishes.
