All of your numbers look dead on awesome with the exception of the CYA levels. For now stop using ANY form of chlorine except for bleach. The trichlor you've been adding has been sneaking in stabilizer as well.....to the point of around 4PPM per bag. This is a normal test that newer users (I'm still reading high all the time) often get high results on. Let's try this test as per the extended directions.......
Other than that however your numbers are looking good.......but let's make 100% sure we get you great on the CYA results and set you up for a great summer. If you're still looking into a SWG and the results are still around 100ish then it's not a HUGE deal as sometime this April we're bound to get SOME rain giving you the chance to drain some of the water to lower the levels to around 80ish.
If your CYA level is 90 or higher, repeat the test adjusting the procedure as follows:
Fill the mixing bottle to the lower mark with pool water.
Continue filling the mixing bottle to the upper mark with tap water.
Shake briefly to mix.
Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark.
Continue the test normally from step 3, but multiply the final result by two.
