- Jun 22, 2014
- 47,759
- Fiberglass
- CircuPool RJ-45 Plus
That certainly could be a concern if it was copper based. The dry acid test might confirm.He dumped in a ton of algicide.
I tried that. The dry acid just dissolved into my water. Nothing happened. I will try again.That certainly could be a concern if it was copper based. The dry acid test might confirm.
Tried vitamin C and dry acid again. Neither seem to budge the stain. Ive also notice the water coming out of my keys seems a bit white. Filter is good. Don’t think it’s air.I tried that. The dry acid just dissolved into my water. Nothing happened. I will try again.
From the picture it appears to be black algae. Very different ftom green.It’s not a green smear. I do have some bio guard super soluable. Should I try that?
I though black algae created a green smear? Regardless, I believe a SLAM is in order. I’m not having an issue holding chlorine and I’ve kept my FC high so this really puzzles me. Should I slam?From the picture it appears to be black algae. Very different ftom green.
Hey TexasSplash, see below. I though black algae created a green smear? Regardless, I believe a SLAM is in order. I’m not having an issue holding chlorine and I’ve kept my FC high so this really puzzles me. Should I slam
Black algae is weird stuff. It actually grows from the outside of the pool in, one cell at a time. Highly chlorine resistant because of a "cap" thst covers the portion you see. Call hypo applied directly will oxidize the cap and attack the algae. Scrubbing with a tablet also removes the cap and applies chlorine to the algae.I though black algae created a green smear? Regardless, I believe a SLAM is in order. I’m not having an issue holding chlorine and I’ve kept my FC high so this really puzzles me. Should I slam?
If you look at my FC levels I don’t know how I’d get black algae. Ive been above target pretty consistently.Black algae is weird stuff. It actually grows from the outside of the pool in, one cell at a time. Highly chlorine resistant because of a "cap" thst covers the portion you see. Call hypo applied directly will oxidize the cap and attack the algae. Scrubbing with a tablet also removes the cap and applies chlorine to the algae.
NoI passed OCLT so doesn’t this not support the theory of black algae?
No meaning you agree with me that it’s not black algae? Or No, it still could be.
Your pool, your time, your money, your choice. I make recommendations based on what I've seen in this business.No meaning you agree with me that it’s not black algae? Or No, it still could be.
Hey pool man, I’m not being a ********, I’m asking for clarification, so a simple answer would be great! I’m here asking for help so no need to be smart about it.Your pool, your time, your money, your choice. I make recommendations based on what I've seen in this business.
Not trying to give you a hard time, but I believe I gave a simple answer, twice. From 2000 miles away, based on your picture and having seen something similar many times, I believe it is black algae. Don't care how high the chlorine level is, I've seen it many many times with well chlorinated water. The algae is actually outside the pool wall, you just see its water source. It produces a cap that lets water in and keeps everything else out. Sprinkling a bit of cal hypo and letting it sit SHOULD get rid of it, at least temporarily. You just keep doing it until it doesn't come back.Hey pool man, I’m not being a ********, I’m asking for clarification, so a simple answer would be great! I’m here asking for help so no need to be smart about it.
