Holydoc
- Jul 17, 2016
- 515
- Plaster
- Hayward Aqua Rite (T-15)
Russell,
While we are at enhancement suggestions, I would like CC, TA, CH, and CYA to all have the ability to quick calculate just like you have done for FC and pH. It is true that those are not needed as much as FC and PH, but I have found that I need them when my levels are dropping or a little too high. For instance today, I noticed that my pH has been dropping, so I tested my TA. Sure enough my TA had dropped from 70, which keeps my pH pretty stable at 7.6, to 50. Now TA=50 was within my acceptable range so I did not get a notification of how much Baking Soda I need to raise it to a more comfortable level. So I had to go into the setting area and overwrite the default to 70 to get the calculation. This worked fine, but it is not as elegant as the "Quick Calculation".
More charts as well. I love them! Would love to see how my TA drops over time as well as my CH and CYA.
Finally being able to input multiple pools would be wonderful. I have a Jacuzzi as well as my pool. Since your app currently only allows input of a single pool, I must use another application to keep track of my Jacuzzi.
In case I forgot to mention it, I truly love this application. Thanks for all your hard work.
