- Oct 25, 2015
- 5,809
- Plaster
- CircuPool RJ-60 Plus
I think the negativity here comes from "experts" at pool stores pushing trichlor pucks (and other chemicals) without the required knowledge of water balance chemistry, especially about the reduced disinfection properties as CYA/FC ratio increases. Once you learn about water balance it becomes easy to use pucks appropriately. For example, many of the TFP users do add pucks in floater for vacation. It works well so long as you make sure you know where you will start and end with respect to CYA ratio. But with the longer season as others pointed out pucks are not a solution unless the owner plans to drain a LOT of water throughout the year. In my experience pool stores never point this out.
I hope this helps.
Chris
I hope this helps.
Chris
