as the title says, the pool manufacturer has to drain my fiberglass pool to repair a peeling gel coat problem.
i also have a lot of iron staining on the walls from the rural water district.
so here’s my plan; i lift the stains with an AA treatment, then drain it. after the gelcoat is repaired, i refill it using a a pentek big blue filter (1 micron) on the end of the fill hose.
does that sound like it will work?
TIA, mike
TIA, mike
