dead algae. Can't be sure from just a pic but that's what it sounds like.
YOu should perform an OCLT and see if you pass that test.
Here you go. Yesterday, my pool was spotless. Today, this is deposited in various places. They are about nickel to quarter sized spots. I can poof it away with my foot or vacuum it. OCLT last night was a loss of 0.Does it look like the stuff in my pics
Exactly what I see all the time . Duraleigh says dead algae and I respect his opinion but I slammed the Crud out of my pool. I have o chlorine loss over night and keep my fc between 7 and 9 . My cya is 50 maybe 55 or 60 at most . Theirs no algae on my stairs or skimmer box. It’s just bizarre that it always comes back and I hate it. I’d pay good money to fix it if I couldHere you go. Yesterday, my pool was spotless. Today, this is deposited in various places. They are about nickel to quarter sized spots. I can poof it away with my foot or vacuum it. OCLT last night was a loss of 0.
You don't have to. But I think you have to accept you have live algae in your pool, a portion of which is dying and settling on your pool floor. You really can't vacuum ALL of it so you have to brush it up into suspension in the pool water so the filter can remove it.I’d pay good money to fix it if I could
Is their any danger in letting peopleYou don't have to. But I think you have to accept you have live algae in your pool, a portion of which is dying and settling on your pool floor. You really can't vacuum ALL of it so you have to brush it up into suspension in the pool water so the filter can remove it.
As a potential fix (and I think it will work), I suggest the 50% increase in FC (keep it there) and run your pump 24/7 and keep daily brushing to keep it suspended.
The best solution that really doesn't take much more time or material is to start over by posting a complete set of test results so we can get on the same page as you and then begin a NEW SLAM.
The SLAM works. It has proven effective on EVERY pool when it is done precisely as the SLAM article dictates. You can fix this issue but I think you first have to accept just what the issue is and then fix it........Likely with a new SLAM.
Algae, while unsightly, is harmless. To be sanitary, FC needs to be between min and SLAM per your CYAIs their any danger in letting people
Swim right now ?
Sometimes it picks particular dents or seams.1. If this is potentially algae wouldn’t it grow in other areas besides the floor bottom ?
Correct. But for every rule, there's am exception to that rule, like Mustard Algae. (I don't think it is, just sayin. Lol)2. If it is algae when I’m at slam
Level (Monday) than this stuff shouldn’t be forming on bottom of pool correct ?
No. When convenient, get rid if it to waste. If not, filter it and backwash.3. Is vacume to waste essential ? I have a manual vac that doesn’t attach to filter I’d like to use
DEAD algae is on your pool floor. Live algae is suspended throughout your pool yet often invisible1. If this is potentially algae wouldn’t it grow in other areas besides the floor bottom ?
I started the slam last night and there was so much stuff on the pool floor this morning . Should I keep the slam going until this stuff stops appearing? I vacuumed and brushed and added chlorine. I was at 24 last night and at 21.5 this morningDEAD algae is on your pool floor. Live algae is suspended throughout your pool yet often invisible
Slamming my pool is exciting for some reason lol
That's because the water was flowing slowly over the pool floor and "piling up" the dead algae along tiny divots and seams or wrinkles in the linerOnly appeared when the filter was running
