Fc 9
Cc 0
Ta 70
Ph 7.6
Cya 50
I went to pool store and had them check to cross reference my readings . The look on their faces when my fc was at 9 . Lmao . They tried selling me phosphate remover. My phosphate was at 500. I told them no thanks .
So I had this problem last year. I have smudge like circles and streaks on the bottom of my pool. I can not capture nor feel it even with my fingers . It’s not attached because I can move it with just moving water on top of it . The color is brown to black sometimes a little white in it.
To combat this issue upon opening this year when I took the cover off the water still had plenty of fc around 13 roughly. Water was crystal clear and the pool bottom was spot free !!!!! I replaced all the pool sand with brand new sand. I have all new hoses . So the sand filter was rinsed , bleached , and basically brand new. I have and use skimmer socks to catch fine pollen and whatever else that may get through the sand .
Someone once mentioned to put a sock on the return line but after many attempts I deem it impossible. Maybe some people have different returns than mine but I can’t figure out how. I think I have a doughboy. Anyways ………
This is the sad story. I vaccume the pool floor. I have an independent vac I use.
It’s hoseless and it gets captured in a fine bag. Almost like a cotton material.
2 things that baffle me . One is if I don’t turn the pump on the floor will look cleaner for longer . Another is I sincerely don’t think it’s algae . This stuff never appears on stairs or sides of pool and my water is always crystal. I have done overnight fc loss tests and it always passes.
I know this isint recommended but should I flocc it ? Is there anything else I can try adding ? I’m ocd and this is driving me nuts . Oh and I did do an extended slam
When I opened just to do it . So I already zapped it .
Cc 0
Ta 70
Ph 7.6
Cya 50
