We are moving from the dreaming to the planning phase of our new home and pool. I have questions and the answers should hopefully guide us down the correct path.
Here is the background or current thoughts. We are planning to build the pool ourselves using ICF's. Pool and Spa Designs out of Scottsdale AZ is going to do our pool design work which will include permit ready construction drawings, electrical & plumbing schematics, and a wholesale equipment list. Since the pool will be a custom design built with ICF's the pull surface will be most similar to a gunnite built pool. We have scrapped the pool level hot tub idea that is shown on the sketch.
Here are the questions:
1. With this pool, what will I need to do in the winter time? Do I keep it full with the heater set above freezing? Do I drain it, blow out the plumbing lines, plug the openings, and partially refill like my vinyl pool friends do?
2. As a follow up to question 1, per the attached sketch, there is an infinity edge component to the design, I can't imagine that I want water splashing over the edge when the outside temperature is below freezing.
3. Are there systems available that will monitor water chemistry and add chemicals automatically?
4. How corrosive are saltwater pools to the concrete and other items near the pool?
5. We love luscious green grass. Any issues planting grass right up to the edge of the sides on this pool? (Which would not be the primary ingress/egress.)
