10k gallon pool with an A&A Infloor system, ASVC main drain and Venturi skimmer. I have zero additional returns besides the 36 G4V pop up heads, no water surface height returns. When they plumbed the skimmer they did not add the return line to the back of the skimmer which is what creates the Venturi effect. On the front of the skimmer I have a lower port that does go out to the pool with a drain cover over it, this port is supposed to be used for the Venturi effect from the Venturi return line which flows through the bottom of the skimmer then out to the pool. As a result of all of this, I have no surface skim effect as the majority of the water the skimmer pulls in comes from the lower port, not the surface. If I plug the lower port by placing a bowl over the drain cover the surface suction does increase. Obviously, I'm not placing a bowl over the lower port drain cover permanently, what do I do? For reference, the G4V pop ups are not yet installed as I was told to wait 30 days bc of new PebbleTec. The system was engineered by A&A but I assume they designed it with the intention of the Venturi return line being plumbed to skimmer. When I questioned the plumber he said the Venturi return line isn't necessary and that the "quick skims are a scam".
Any advice or help is appreciated, thank you in advance!
