Disclaimer: This year will be the 1st full season with a pool!
Simple question.. How do you all know what/how much to put in after getting readings? (I tried using the calculator and that wasn't really intuitive as I would have liked, although, I should spend more time with it.)
I ordered and used the TF-100 Kit and got the following results. I'm afraid of adding in too much shock and may raise the CYA.. which I'm trying to avoid replacing water.
Pool was opened last week, added in 6 Gallons of shock, life got in the way and therefore, wasn't able to keep up with it. A week later, the results are below. The water was clear and then it got greenish but mostly with sediments on the pool floor. Just trying to get this thing up and running. Trying to avoid the pool store as I want to learn this on my own.
FC - 1.5
CC - 2.5
CYA - 35
PH - 78
Looking forward to hearing all the advice. Thanks!!!
FC - 1.5
CC - 2.5
CYA - 35
PH - 78
