Hi, I am about to start looking for a reputable contractor to carry out the replastering of my 33-year old pool and spa. The pool was 5-years old when we bought the property and to my knowledge, has never been drained or had any major repairs carried out. We live in the north Tampa Bay area and are well aware of the history of Florida pools popping up due to high water tables, while work is being done on them.
At first, I just assumed that it had a hydrostatic valve installed in the main drain and intended to replace it but have since discovered that there is only a plug. After reading about the issues others have had with hydrostatic valves, sometimes due to debris being trapped or spring failing, I'm wondering if I would really be better to continue with just a plug. I understand Hayward recommends having a collector tube (SP1055) used in conjunction with the valve but I don't think this could be installed retrospectively without removal of the drain sump itself. Has anyone done this?
My thoughts are that as the pool has survived for so long without a valve and I'm not too keen to have to replace it every seven years or so (also recommended), is it really worth installing one now? I don't anticipate having to drain the pool again in the next twenty years or so and if it does require to be done, the plug can again be removed to allow any groundwater to enter the pool.
I'm open to suggestions from other forum members regarding this.
Regards,
Al
Regards,
Al
