My pool came through Florence intact (exept for pool fence). Here's what I did:
Drained water down about 8"
Took pool to shock the morning of the hurricane,
Covered with mesh winter cover (against the advice of some)
During the storm - 15+ inches of rain, 48 hours of sustained 30-40 wind, including tropical storm force winds. Tree falls against pool, destroying part of pool fence. Branches landed on mesh cover.
After the storm - no power and no circulation or chlorine x 96 hours.
96 hours after the storm, power back on. Cut tree and removed branches from mesh cover. Removed cover.
FC~6, CYA~40. Water - slightly cloudy. No leaves at all. Pool water up to top of pool.
Drained down to mid skimmer level.
Took pool to shock again.
Ran DE filter x 6 hours. Water again TFP clear.
The mesh cover was not damaged but kept tree branches from touching my vinyl liner. However, the rain and wind put some fine contaminants in the pool that went through the mesh cover. This caused cloudiness that cleared easily with filtration.
Damaged portion of pool fence must be replaced.
