Hi !
I posted here a few years ago when my conditioner level was terrible and I had to deal with some yellow algae. I ended up chlorinating the Crud out of the pool that summer.
The recommendation was to dump water. In the fall season that year we had terrible fires in CA and my house almost burned to the ground. When I cleaned up my pool afterwards I dumped about half the water because I just sucked the ashes out of the pool that way. Using the Filter in Backwash mode.
Then we had an enormous rain season, just like this year. So I got calcium free , FREE, refill. Awesome!
My conditioner level was back to 50... and I was able to use "normal" amounts of pool chlorine and use the regular test kits.
Last year, using the solar cover, I got the pool to be about 95 degrees for 2 months. A giant hot tub, so much fun at night. But I noticed in July starting to get black spots all over. At first small, then bigger and more. By the end of august I had them everywhere. Brushing off with metal brush not very effective. I have seen those before years ago and they normally would go away in the winter time when the water goes to 45 degrees.
They did subside a little bit this year too but not enough. Now the water is back to 80 degrees. How the heck do I get rid of these black spots? It doesn't seem like shocking the pool kills them.
Thanks! - Just got my refill kit here so as soon as I get it I can make measurements. For now, using my regular test kit. Chlorine 5, Ph 7.5.
