- Oct 25, 2015
- 3,805
- Plaster
- CircuPool RJ-30 Plus
Here's the default schedule starting on page 5. The next few pages show how to customize to your needs.
Digital inputs can be any signal that is 12-24 vac or dc. So if for example you set "STEP 1" speed to run at 1700 rpm 24 hrs you can engage "STEP 2" speed to run at 3000 rpm when the solar valve opens by sending the same signal that closes the solar bypass valve to "STEP 2". The motor will revert to the internal schedule (clock) any time there is no digital input.
