Thanks. Bunch of rain in the forecast. I will do a full test after the rain passes. I guess I should slower the SWG a bit. I have it at 40% pump running 24x7Over 5.
Use a FAS-DPD test for FC testing.
That depends on what your CYA level is. 5FC might be just fine.Thanks. Bunch of rain in the forecast. I will do a full test after the rain passes. I guess I should slower the SWG a bit. I have it at 40% pump running 24x7
Your PH is around 8.2 by looking at the picture in your test. Use the drop test to test for chlorine, not that test with the color change. It can only test chlorine up to 5ppm. You need to keep your chlorine level in line with the CYA, which could possibly be way higher then 5ppm.Thanks. Bunch of rain in the forecast. I will do a full test after the rain passes. I guess I should slower the SWG a bit. I have it at 40% pump running 24x7
On Friday my CYA was around 25/30Your PH is around 8.2 by looking at the picture in your test. Use the drop test to test for chlorine, not that test with the color change. It can only test chlorine up to 5ppm. You need to keep your chlorine level in line with the CYA, which could possibly be way higher then 5ppm.
The Free Chlorine and Cyanuric Acid Relationship
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.www.troublefreepool.com
Lol, we told him three times now…Maybe, maybe not.
Without knowing your CYA, there is no telling what your FC target range should be.
FC/CYA Levels
The OTO test you used only show that there is some chlorine in the pool water. It looks to be above 5, but what is it really. Test it now, before the rain. Better yet, post a full test of test results. You can adjust the FC again after the rain event.
Go with 30, use pool math to determine how much chlorine is needed based on the gallons of your pool to bring it up to 12.On Friday my CYA was around 25/30
