- Aug 23, 2022
- 374
- Vinyl
- CircuPool RJ-60 Plus
Would you recommend a certain manufacturer/type?The cheapest, thinnest one you can find. The flimsy bubbles are the same on all of them, and the usual fail point. If you spent more on the thicker cover, you'll be upset when the bubbles popped anyway.
The thicker cover is less prone to rips, but being unmanageable heavy when wet makes it more likely to get snagged on something.
They all stop the same evaporation which is where 70% of your heat loss comes from. Pay no mind to any of the manufacturers claims that their cover makes heat, or retains more heat.
Blue. The 'clear' one I had was hideous. It was opaque at best and with any air pockets or enough air around the bubbles, it was white.type?
The cheapest one you can find.manufacturer
Correct.Ok, I'll look into one in Amazon. I assume this has to lie on top of the water and it's not just suspended above it...
Can I use the reel with the diving board?Correct.
Check Sun2Solar website. They are sold on Amazon as well, but the website was almost 20% cheaper.
I like having a reel. If I didn't have a real... I would use it. It's a PITA to wrangle and fold otherwise. The reel makes it a 2-minute process.
Can I use the real with the diving board?
Put the reel on the opposite end? Is that a possibility?Can I use the reel with the diving board?
Stairs are there. The shape is the same on both ends tho.Put the reel on the opposite end? Is that a possibility?
I mean, I don't keep my reel there. I move it into place, and out of place... About 10ft linear to make the patio look cleaner and allow more room for people to jump in, and walk around the pool.Stairs are there. The shape is the same on both ends tho.
I meant, I think I'll have the same issue as the deep end with the board, as there is a railing near the stairs.I mean, I don't keep my reel there. I move it into place, and out of place... About 10ft linear to make the patio look cleaner and allow more room for people to jump in, and walk around the pool.
