George,
I think the IC40's flow switch comes on at about 25 GPM, but it does not matter what it should do, it only matter what it does do.. With a clean filter start at about 1200 RPM and see if the flow light on the cell is green.. If not, adjust the speed up until it just comes on and then add 100 or 200 RPM for when the filter gets a little dirty.
I run at 1200 RPM because I do not have a heater.. With a heater you will most likely have to run at 1500 to 1800 RPM.. (Unless you have a heater by-pass)
I believe that if you are running the pump, you should be making chlorine. My pump runs 24/7 because I like making a little chlorine all the time and I love skimming all the time.
Jim R.
Jim R.
