- May 3, 2020
- 56
- Plaster
- Pentair iChlor 30
Hi all,
after (too) many SLAMs over the past 1.5 years I think I have established that the SLVS that's installed on my pool is the culprit...
(previous post on the topic, just as background: Pipe in my yard - no idea what it's for)
As I'm again going through a SLAM, I've looked again at this SLVS and I have established that the water in that pipe is most definitely stagnant - I took some of it from the open pipe (about 24 inches down) and tested it for chlorine (FAS-DPD): there was absolutely none in it. The water was dirty as well, like soil got into it...
So, I switched off the pump, opened the filter (cartridge), drained all the water and put everything back together. I then watched the content of that pipe while I remotely (from the app on my phone) switched the pump back on and saw that while the pump was priming it basically sucked out all the water from the pipe. Once it was primed and started running at normal speed, the water returned to the pipe. I repeated this exact thing a few times more, this time also closing the valves of the robot and the skimmer and could see the dirty water ending up in my pump.
So I believe that every time the pump has to prime or a vacuum-like event happens (like I had recently when the hose for the suction vacuum robot was disconnected and that suction port closed quite abruptly) it's pulling in that and may very well be causing the cloudy-ness of my pool once it gets mixed back in with the main pool water... It's not impossible that my variable speed pump is much more powerful than the pump that was originally there and the change in the valve layout (the original pool didn't have a suction valve for the robot), is making this SLVS inadequate.
So, to my question: as I have 2 main drains, I don't see the need for this SLVS (they don't put them in new pools anymore in FL) so I want to suppress / disable this thing all together. Now, as I'm not an expert, I was hoping if anybody here could give me a pointer as to how to do this? I mean, I know I'll need to cement a PVC cap on the pipe but is there anything else I need to think of? Can I do it just below ground level or should I try to go deeper (though it may cause the pipe to overflow if I go below the pool water level)?
B.
B.
