Hey Guy's,
I recently tried to change the "divert-er valve" inside a PVC "Pentair Check Valve housing" only to find that several screws were stripped inside the housing. So, now I need to replace the PVC Pentair Check Valve housing.
As I see it, the problem becomes how to remove the old housing as it was installed up against an elbow. In fact that elbow is attached directly up against two "Pentair Check Valve housings". Each housing cost about $45, Ouch!
Maybe someone here has run into this situation before and can give me some tips. Preferably, as low cost as possible. I have already purchased a new Pentair Check Valve housing.
Thanks in advance,
Mose
Thanks in advance,
Mose
