Greetings,
I am in my sixth year of pool operation and am struggling with how to approach balancing my water. I need to add about .5 gal MA each week to keep the pH from going above 7.8. My understanding is that the acid will continue reduce the TA (or at least hold it lower than desired). Is that correct??
I have observed that TA recommendations vary (with respect to the lower limit) quite a bit depending on the info source
TA recommendations from various sources
70 - 90+
80 - 120
80 - 120
60 - 120
100 - 120
80 - 120
Pool was completely re-filled in Jun by local twp from hydrant. Fill was necessary because of a bad hydrostatic valve.
Prior years' TA was between 90-110.
Thanks in advance
current | my target | ||
pH | 7.8 (H) | 7.5 | |
FC | 3 | 3 - 5 | |
CC | .25 | ||
TA | 50 (L) | 80 | |
CH | 250 | < 400 | |
CYA | 30 | 40 |
70 - 90+
80 - 120
80 - 120
60 - 120
100 - 120
80 - 120
Thanks in advance
