This is the first year I've attempted to close the pool by myself. I can't figure out how this plug fits in. I unscrewed the return eyeball but there is another piece in there that won't allow the plug to fit. What do I unscrew? I'm afraid of cracking something.
SP1419T - TOOL,BALL SEAT REMOVAL PLASTIC KEY WG (SP1419T)
www.inyopools.com
The whole part comes out. There are notches in the remaining part that you can use the above removal tool or you can find something that fits into the notches.
Hey @IrishEyesSmiling ! Fwiw I put screw my plugs into the outside after removing the plumbing. Also lower the water below the skimmer a couple inches or so - as rain water collects on the cover it will displace the water in the pool & it will fill the skimmer. It’s recommended to pump the cover off regularly to prevent this. A dry skimmer is a happy skimmer
