- Jun 17, 2019
- 58
- Plaster
- Pentair Intellichlor IC-40
I'm looking to experiment with rotating spa jets in place of the standard eyeball returns in my spa. I'm pretty sure that I have Pentair eyeball returns since all of the other equipment is Pentair, but once I get the outer ring and eyeball out of the fitting, how can I tell if the inner fitting is slip or threaded? Does the presence of two grooves opposite each other inside the fitting indicate it is a threaded insert? The last thing I want to do is to try to force one of these out only to find that it's a slip fitting and that I've busted the outer pipe in the process. This CMP jet is what I'm looking to try.
