my pool is supplied by well water and had iron stains pretty bad. did the ascorbic acid treatment per the old thread started by mbar. ended up using 6 lbs of ascorbic total in 20,000 gal pool and got most but not all the stains. added a total of 4 quarts of proteam metal magic after the AA, kept ph =< 7.2 and Chlorine at 0 for 5 days after treatment - the cloudiness of the water cleared a good bit, and i added 1 gal of pool bleach (10 percent) at day 5 post treatment. water had a green tinge 24 hours later and chlorine was zero. (i used a total of three quarts of Combat polyquot 60% starting a few days before treatment and for the 10 days following AA treatment. pool is notorious for green algae growth.) well at 7 days post treatment the water was getting greener and i used two gallons of chlorine bleach to try and stop the algae - in about an hour the water in the pool turned dark brown! so i added 2 quarts of proteam metal magic. (guess i shouldn't have added the bleach, but i wanted to stop the algae. ) at 9 days post treatment i added two quarts of natural chemistry metal free - it lightened up a bit by the next day. had to go out of town overnight got back tonight and water is dark brown again. i have tried stuffing poly fill in the skimmers - didn't trap any brown stuff. i am at a loss for what to try next . any suggestions? should i just get more ascorbic and broadcast it in the pool?
today the chems are:
ph 7.0
alk 80
chlorine 1 ( put a couple tabs in the chlorinator cause i was going out of town)
appreciate any help you might offer.
ph 7.0
alk 80
