- Oct 4, 2018
- 90
- Vinyl
- Autopilot Digital PPC1 (RC-35)
In the summer when I'm not around, I sometimes have someone stop by to backwash my filter, empty the skimmers, and check my chemicals etc. However a problem we've been having is that the water level is too low to backwash, and it can take an hour or more to top it up. The pool has no main drain, so the system will deprime if the level drops below the skimmers. My hose runs on 1/2 inch copper pipe.
I have looked at autolevelers but that seems like a pain to install unless I want to run a hose over the deck, plus I worry about it leaking.
What if I plumb a 3/4 or 1 inch line to the pool area and use that to fill? Would I need a special hose? Would there be any risks? I'm on town water, not a well. Pressure around 80psi.
