Hello all. My Jandy CL460 cartridge filter split open, so I am replacing the filter unit. However, the new unit was redesigned by Jandy, so the PVC lengths are slightly different. Before I start cutting the new plumbing, I wanted to ask two questions.
1) Can I use water (or another lubricant) to test the newly cut PVC pipes/unions before I glue them? Without lubricant, the pipes do not seat as deeply as they do with primer/cement. I'm guessing there is a good option for testing the connections.
2) What is the best way to guesstimate the required pipe lengths before I start cutting? Again, I'm hoping someone has a simple method or video to help me piece this project back together.
Thanks!
Nick
Thanks!
Nick
