So, I have had a rubber hose come loose on my pump setup. It began shooting out water at a fast rate and so I put a stainless steel hose clamp which did the trick for a little while. I would like to fix this properly but I have no idea where to begin. If you look at the photo the hose is running from the pump to a PVC pipe sticking out of the ground. I do not know what all the pipes are for as I'm relatively new to being a pool owner. Any help is appreciated! Please let me know if more info is needed!
