How to connect pool heater natural gas line to stub up
ForceEdge
136
Long Island
CircuPool RJ-60 Plus
So i don't know if I'm just not understanding this but how would i connect threaded pipe to this if everything has to be tightened. once i reach the heater how would i connect? do i need to use reverse threads or am i just not thinking about this correctly
it is a raypak avia
Check with your local building department to see if they require a permit and/or inspection.
Nautural gas leaks are no joke.
Reactions: ForceEdge
THANKs so much!
Yes, everything was already permitted, the 2 inch line run to the stub up already has an inspection/gas pressure test done. The connection to the pool heater just needs to be made and they come in for a final inspection to see if it was all connected correctly and fully pass it.
so i was going to connect the heater myself
