Not closing for several weeks, but I want to have everything ready.
We freeze pretty hard here, so I need to blow out the lines. Because of the power cover I can't drain the pool down, so I have to blow everything out and plug it. Last year the pool builder closed for us (1st one's free...). He used a blower and had a rubber cone shaped adapter that plugged the hose into the 2" pvc lines when the pump and other accessories were removed.
I will be using an air compressor. I've seen posts where they say to screw a quick air coupler into the drain port at the pump, but I would like to avoid that as the pump housing is plastic and a stripped thread would be an expensive mistake.
Basically the access I will have with everything removed I will have half of a pvc union on each end - the connection to the pump on the suction and the connection to the (unused) Nature2 feeder on the return side. What's the best way to get from those openings to a 1/4 female pipe thread to accept the quick connect or even just screw in the air hose?
