How to change to a new wifi on my Pentair Intelli Touch i7+3 control panel?
palstc
3
Corona, CA
I use the Screenlogic app and I recently changed my wifi system which has a new name and password. The Intelli Touch does not have a screen so I can navigate wifi there. I can't do it theough the Screenlogic app. What do I do?
Welcome to TFP,
I believe your IntelliTouch should have the 900MHZ wireless link that does not connect using WiFi. The outdoor unit connects to an indoor receiver that is wired to your home network.
Did you change to a mesh WiFi router?
What does not work?
If you get " ERROR Cannot connect” after replacing the router, then you will have to reset the Protocol Adapter because you changed the router.
Push the reset button 3 times. It is inside the little hole in one end of the adapter.
The Screenlogic adapter must have a firmware version of 5.2.736 or above for the reset functionality to work. Previous firmware versions does NOT support resetting to clear its IP settings, so don't keep trying.
I get a login failure in Screenlogic that days to check the wifi.
Show us a screen capture of the message.
Also show us a picture of your outdoor antenna connected to your panel.
What model is your new router and modem?
