- May 18, 2015
- 339
- Plaster
- CircuPool RJ-60 Plus
I’m thinking ahead for closing the pool. Each year I drop the water level down low enough so it’s below the returns. I always lower the water, blow them out, add pool antifreeze at the equipment pad and blow that through as well. Then plug them. The issue is that it’s about 16” of water as opposed to the 4” I need to get below the skimmers. Seems like such a waste. Is there a good way to thoroughly blow out the returns while they are still under water? They are non threaded so a duck plug/bungee plug will not work.
