- Apr 10, 2018
- 5,247
- Plaster
- CircuPool RJ-45
The SuperFlo VST will work with higher end Pentair automation systems such as IntelliCenter and EasyTouch, but not the IntelliConnect. The SuperFlo VST is a better choice if you decide to go with DIY automation. The cable connection provides digital inputs for control of three speeds along with a 5 volt common wire to power the inputs for use with dry contact relays. The IntelliFlo only provides RS-485 (2-wire) control for compatible systems and does not allow direct connection to relays. In my case, I used an existing Pentair IntelliCom to convert IntelliFlo RS-485 signals for use with the relays.
The SuperFlo VST is a great pump. As Allen mentioned, decide on what direction you want to pursue for automation.
