I recently inherited an in ground pool/spa and I'm a bit confused about the plumbing setup/main drain and how I would air lock it.
Some info on my pool setup (Also see attachment for pics of setup):
On the pool suction side, there is another 3 way diverter valve to isolate 1 of the 2 skimmers, or have both open.
On the spa suction side there are 2 pipes coming up from the ground and they join into 1 PVC tee but there is no diverter to isolate the skimmer or main drain.
So my question is, how would I air lock the main drain in my spa if I cannot isolate the main drain? When I blow out the lines I can see bubbles coming from the main drain, but there is also air coming out of the skimmer.
Don't I have to isolate the main drain to create an air lock? Or am I wrong on this?
- Inground vinyl pool/spa
- 1 pump, can only pull from pool OR spa, not both (has to be controlled with valves on suction side)
- Pool
- 2 skimmers
- 2 returns
- NO main drain
- Spa
- 1 skimmer
- 6 returns
- 1 drain on floor
- No spill over, or extra features
- No dedicated vacuum line
