Hi,
I searched and searched the internet for an answer, and couldn't find one. So I came these forums.
For aluminum pools, roughly how thick is the sheet metal? I know the thickness varies between pools. But roughly, what would be the range of thickness that would be typical?
Also, if the walls of a pool are aluminum, would the supporting structures along the side most likely also be aluminum? Or is it common to use a different metal for the supports than the walls?
