PB came and turned on my equipment today, new pool /plaster. PB insisted that in order to clear the plaster debris from brushing I must use the vacuum which has wheels every time after I brush. ( the one you attach to the skimmer) . This is opposite of everything I have read and been told. and what is on the plaster start up sheet from manufacturer. I have stonescapes pebbles with glass beads added.
I thought I needed to do the following
1. Not put anything in the pool with wheels or a robot for 2-3 weeks
2. Brush 2-3 times a day.
3. Watch my filter pressure and back wash as needed when pressure rises above my clean pressure . I have a Hayward Sand filter with Glass Media and a Variable speed pump which they set to 80% running 24/7
I am confused.
Is it best to use the vacuum after I brush ? If so is this ok for the plaster?
Wil not doing this screw up my filter or something?
Can the filter handle all the plaster dust from brushing without me vacuuming ?
Hoping for some feedback on what would be best as I need to start brushing
I am confused.
