Hi All,
I'm about 8 months into ownership toying with the equipment and optimization. And wanted to ask opinions.
Right now the return water is split between the spa (for spillover water fall) and pool return. The pool return creates nice circulation- the spa is okay but spillover doesn't quite make it into the pool cleanly. It seems to splash on the stone below. The PSI reading is around 10 psi when the valve is open for both.
Today I closed off the pool return to run spa only. It did great at spillover getting into the pool cleanly and filter psi was at 20 PSI which is on the high side but when I did it the pump ran quieter. Usually with both returns open it's a little louder like the water in the filter is maybe sloshing around. Only having one return open made it really quiet.
Pump is an old Hayward Northstar 2 hp 2 speed pump. Ideally I'd like the spillover to be more powerful to clear the bottom stone without compromising the pool return and rasing PSI into the 20s. Leslie's has a jacuzzi 2.65 VSP pump on sale with free install. Would a VSP with more flow be better to have both returns operating better or would closing part of one of the return valves be better?
