G
Guest
She said that she put in 3 lbs. Reread her last post!rbonin said:Hey amieelynne... why don't you put some CYA in your pool? :-D
The vials are arranged in this order left to right on the rack: FC, TC, pH, CH, TA, CYA, Copper, Iron, (and if they have the upgrade then Nitrate and Borates).MikeInMo said:WaterBear,
What is the proper development time on those tests? The system described sounds like what one of my pool stores uses. Little square vials with foil coverings that the tester punches thru with the ?pipette? [learn a new word every day]. The vials are probably somewhere bt an inch or two in height and the color of foil varies, assuming with the different test. I tink what my store does is just fill all the vials at once and then run them thru the meter one by one. I assume that the vials first filled are the first anlayzed but it doesn't appear that there is any set wait time.
Is that what you'd expect?
I just recently purchased the LaMotte ColorQ and am enjoying the geek factor but the directions never mentioned any wait times except for the CYA test. Based on your experience with other LaMotte products what special procedures would you recommend (i.e. wait time after adding drops before analyzing or wait time bt adding reagent 1 and reagent 2, etc.)
Mike
amieelynne said:thanks everyone...for the stories about your local stores and testing...I've got a handle on home testing now (or at least I'm deluding myself into thinking that..lol) so I'm staying far away from that store for any info from now on. I did take a sample in today, just for ha-ha's, since I needed a solar reel there anyway. they were wrong yet again...told me my cya and ph were low--that I needed x # of lbs of stabilizer and ph increase HAHAHAA. my cya is at 30 and ph is 7.2, but not that off to require lbs of anything. I now believe that they read tests according to what they overorder each week![]()
