Looking for some wisdom from those in NE (or other heavy snow/cold climates) with in ground pools, especially those with stone coping.
I will be closing my 16*32 radiant in ground pool sometime in November. I'm waiting for all the leaves to fall and then will remove solar cover and clean pool. The water temp is still 57, just getting below algae temps.
Here is my plan, then I'll raise my concerns.
My patio will be stone pavers with stone coping, so I am concerned with how low to drain the pool. Winters here in MA can bring over 100" of snow easily. Some of that snow will melt between storms causing the water level to rise, then freeze again. If the level rises to the top of the pool and then freezes again I am worried about popping the stone coping.
I am curious how others in heavy snow areas deal with this?
Thanks
- Remove solar cover and vac pool
- Shock pool, add algaecide, run pump another day or two.
- Drain pool about 1 foot, blow out lines.
- Drain filter, remove cartridges, and drain pump.
- Winterize underground lines.
- Plug returns and skimmer lines.
- No cover this year, the patio is not complete yet. I will engineer a way to anchor a mesh safety cover for next winter.
Thanks
