How long to wait to swim after adding dry acid?
Dry acid is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
Run the pump and brush if you wish. You can swim after a few minutes.
Best is to use muriatic acid.
Reactions: lastevns
Too late , I already poured it directly in the pool ( I read the instructions instead of asking here first like a dummy). Given that should I wait longer? My pump is on.
Be sure you brush the area VERY WELL. As long as you do that, you should be OK to swim.
