Current chemistry:
FC: 3ppm-8ppm
pH: seems to be rising pretty quickly, takes maybe 1wk to rise from 7.3 to 8.0
TA: 160ppm (I'm dropping pH to ~7.0 periodically with muriatic acid to try and reign this in, but haven't seen much change in the two cycles I've done so far)
CH: 260ppm (I am chlorinating with unstabilised CalHypo until this reaches 350ppm)
CYA: 48ppm (recently diluted from 210+ppm)
So far I've put maybe 2ga 31.45% muriatic acid into the pool, but haven't seen any movement in TA outside the margin of error. Max I've tested at was 170ppm, and it's currently testing at 160ppm.
The first time, I dropped to 7.0 and aerated to 7.3. pH was back to 8.0 within a week.
Today, I dropped it to 6.9 and added 1lb Cal Hypo (so it's temporarily spiked back to 8.0, and will presumably settle at or above 7.0 anyway since we were splashing around for a while today afterwards)
Am I being impatient, or is something suspicious/wrong here?
FC: 3ppm-8ppm
