Opened up in New York two days ago to green/algae. With mesh winter cover, CYA had gone to 0 so immediately added 4-lbs bag in sock (all since dissolved). Ph at 7.2. We skimmed the top for floating clumps of algae and then added SLAM level of liquid chlorine and have been running the pump and Dolphin robot nonstop. We also brush all surfaces with the long pole. FC has been holding above 15. There is now very little algae/other floating on the surface and if you pull a glass of water from the pool, water is clear in the glass. But as you can see in picture below, water is still solidly green. Is this just a "keep FC up and wait it out" procedure or is there something else I should be doing/thinking? Appreciated!
