I have a 30x52 above ground chlorine pool. I have a TF-100 test kit.
My CYA showed 120 so I let half my water out, refilled it, let the pump run for 24 hours and retested. My CYA was 95.
I repeated the process and my CYA is now at 70.
Why didn’t it reduce by half each time I drained it?
If I empty it again to get it closer to 40/50, how much should I empty?
Also, I use chlorine tabs in my online chlorination. This also raises the CYA level, correct? So how do I prevent that?
