I have a Hayward Aquarite 940. Salt level is 3200, water is balanced and at 62 degrees in the N FL winter. it has been in operation since August 2019, so it's 2.5 years old, almost out of warranty.
I find myself having to keep it at 35-40% to maintain FC (as opposed to what should normally be 10-15% this time of the year) and on occasion there's a day where the FC drops during the day 1-2ppm like the salt cell was off with no one using the pool or changes in temp/sunshine. I add liquid chlorine and then it's fine like nothing happened for another week+. The overnight FC test passes with flying colors so we're not talking about algae. If I manually adjust the dial, I hear the buzzing noise go in and out. The flow switch has been pointing in the right direction and has not been touched since day 1.
What are the signs that a SWG is going bad? Is there any testing that can be done before I engage Hayward support? Is there a way to test the flow switch and could it be working on and off? Before I start going rounds with them. which is what I expect, I want to make sure that I've done all that I can. Thank you in advance!
