My CYA was measuring low this AM (it rained quite a bit in the past couple of days) so I added 4 oz (5500 gallon pool, recommended was 8 oz on pool math but I do half and then check).
Unfortunately I hadn’t had my coffee yet and wasn’t thinking clearly at all, so I just sprinkled it in around the edges of the pool. Then I remembered I was supposed to put it in a pool sock in the skimmer.
Of course the dry stabilizer settled to the bottom, I put the vacuum in the spa and will switch it to the pool in an hour, and I brushed the bottom and will brush again in about a half hour, but then I need to leave for work.
I can also heat the pool if that would help it dissolve more quickly? It’s newish plaster, the pool is about three weeks old. How badly did I mess up here?
