First a little background. Our infinity pool trough can sometimes overflow if a lot of people jump or make waves in the pool. You can mitigate this by running trough suction high. If large amounts of water had been splashing out of the main pool during swimming that difference gets magnified on the trough once they stop making waves. The trough therefore risks sucking dry once people stop swimming, especially if pump speed was set to high. (The trough has autofill, but needless to say it has no chance of keeping up with a pool pump pumping at the speed people are splashing in the pool. )
Question: Is there a way to let the trough water level signal the trough pump to smoothly vary the speed to keep the trough level within a certain range?
Pump speed to program:
INPUT -> RESULT
level within range -> normal pre set seasonal skimmer speed
water level high -> higher speed
water level low -> lower speed
overflow -> max speed
water level approaching empty -> stop pump
The trough pump is a Pentair intelliflo VSF. I have looked at Pentair's site and don't see anything about this.
Any ideas for a solution would be appreciated
INPUT -> RESULT
