View attachment 77994Hi everyone!
We've posted a few times and we're finally ready to start. We've settled on a PB that we've got a good feeling about but before we sign, we'd like to know from you guys if what we've got is what you'd do again if you were re-building. We've been looking at the "What Would You Do Different" threads and we're hoping some of you will look at what we've got below and let us know, based on your experience, if it's good. Any help is appreciated here. Thank you!
We're building in Houston, TX. We are located in the city (not surrounding areas).
General Specifications:
Pool Perimeter: 78
Pool Depth: 3.5' x 4.5' x 4'
Area: 302
Fence R/R Sections: Yes
Concrete Removal: 186
Saw Cut: None
Stumps: None
Pool Gallons +/-: 7800
Excavation Method: Standard Machine
Haul Dirt Off: Yes
Steel and Plumbing
Main Drains: 2
Overflow Line: No – Per city code
Steel: 8" O.C.
P-Trap: None
*Gas line: Inc.
Pool Skimmer(s): 2
Backwash: None
Pool Return Lines: 4
Fill Line: Manual Fill Line
Electrical - includes up to 100' of electrical run
Over 100': 55
SubPanel: Yes
Light Switch Location: At Pool Equipment Pad
Extra Switches: None
Extra GFCI(s): None
Electric Notes: None
Tile and Coping
Pool Tile (Std): 6" Tile
Trim/Spot Tile: None
Pool Coping: Travertine - Std.
Deck Laterals: None
Flagstone Veneer: None
Brick Veneer: None
Decking
Deck Type 1: Travertine Pavers
Type 1 Square Feet: 400
Deck Type 2: None
Type 2 Square Feet:
None Top Existing: None
Existing Square Feet: None
Deck Drains: 4 Inch PVC Pipe
Drain footage: 145
TurnDowns: None
Deck Steps: None
Tie in Downspouts: One
Interior Features
Bench(es): 1
Tanning Ledge(s): 1
Beach Entry: None
Set Entry Steps: Included
Extra Entry Steps: None
Ext. 2nd Step: None
Gunite Table: None
Fourth Step: None
Raised Pool wall: 21' of 6" Raised wall and 15.5' of 12" raised wall
Material on Front: tile or ledger - standard grade
Material Back: unfinished gunite
Columns on wall: None
Wing Walls: None
Pool Plaster: PebbleSheen Grade 1
Pool Equipment
Pool Pump: TriStar Variable Speed
Pool Filter: Hayward 525SF Cartridge
Purification: Chlorinator
Auto Cleaner: Hayward Navigator
Pool Light(s): Color LED
Quantity: 1
Pool Controller: E-Command
***Heater: Hawyard 400k BTU
Chiller: None
Booster Pump 1: Hayward 2HP Booster
Booster 2: None
Spa
Spa Included: Custom Spa
Spa Jets: 6
Spa Raised: 6 Inches
Spa Blower: Silencer
Spa Light: Color LED
Water Features
Spillway: Negative Edge
Veneering: Standard Tile or Ledgerstone
2' Scuppers: 3
Bubblers: 1
Also adding remote system (smart system controlled from an app) for Pool Equipment.
Pool Perimeter: 78
Area: 302
Saw Cut: None
Stumps: None
Haul Dirt Off: Yes
Steel and Plumbing
Main Drains: 2
Steel: 8" O.C.
P-Trap: None
*Gas line: Inc.
Pool Skimmer(s): 2
Backwash: None
Over 100': 55
SubPanel: Yes
Extra GFCI(s): None
Tile and Coping
Deck Laterals: None
Brick Veneer: None
Decking
Deck Type 2: None
Type 2 Square Feet:
Drain footage: 145
TurnDowns: None
Deck Steps: None
Interior Features
Bench(es): 1
Tanning Ledge(s): 1
Beach Entry: None
Ext. 2nd Step: None
Gunite Table: None
Fourth Step: None
Wing Walls: None
Pool Equipment
Quantity: 1
Chiller: None
Booster 2: None
Spa
Spa Jets: 6
Water Features
2' Scuppers: 3
Bubblers: 1
