A year ago, I started up my hot tub in the fall and a day or so after getting up to temp, the GFCI breaker started tripping. After some experimentation, I found the problem was with the heater element. The failed unit was quite rusty looking, which I blamed on the SmarterSpa Drape Over SWG (or more accurately, the salt).
So I ordered a replacement element, installed it and went back to using chemicals instead of salt. All was well with the heater right up until I drained the tub in the spring.
Now I started up my hot tub and once again, a day or so after getting up to temp, the breaker has started tripping. Once again, it seems to be the heater element. I took a multimeter and found there's 10 Ohms between the two connectors, but also 10M Ohms between the connectors and ground.
Am I just unlucky or do I have something else going on?
