We recently had an integral colored concrete (Davis Colors Pewter) pool deck with coping poured and stamped, and it turned out to be a little darker than we expected, and unfortunately, very hot. The concrete was a 6 sack mixture, so it has a smoother/denser finish which may be causing it to retain more heat and/or feel hotter.
It's hard to know how much of the heat is due to the color vs the texture, but just to give an idea, today it's around 90 degrees outside and an infrared thermometer measured the pool deck at 135 degrees on average, 145 in some spots!! For reference, the black asphalt in the street by my house is around 137. This summer it will get up over 100 here, so I think we've got a big problem.
Aside from feeling horrible about this, I'm wondering what a good solution would be. I've read about concrete paint and overlays such as Sundek. The main thing I'm wondering: would an overlay be necessary to get the temperature down, or would a lighter colored paint be enough? Any general advice? I'd lean towards whatever gets the temp down and is lowest maintenance since I know overlays will fail eventually.
